Ethernet connection
Ethernet connection
Postby theexhaustman on Thu Aug 01, 2024 6:10 pm
This might seem a very basic question;
I'm upgrading from M880, ADL, PDM 32 to M150, ADL3, 2x PDM30 or 32's.
With the previous setup I obviously used a Motec UTC to connect to each of the hardware devices. I will obviously need to retain this to connect to the PDM's.
The question is, do I have just one Ethernet connection to allow me access into the M150 and ADL3 or do they need one each ?
Thanks in advance.
theexhaustman
Re: Ethernet connection
Postby SOReilly on Fri Aug 02, 2024 10:41 am
Each device requires separate ethernet wiring they cannot be spliced together.
If you wish to connect the M1 and ADL3 to the PC at the same time you would need a network switch or a PC with multiple ethernet interfaces.
SOReilly
Postby theexhaustman on Fri Aug 02, 2024 8:44 pm
Thank you.
theexhaustman
Postby greenamex2 on Sun Aug 04, 2024 5:50 pm
Hi
Having three ethernet Motec devices (so far!) in my car was also causing me issues so I ended up fitting an automotive router/ethernet switch.
Now all accessible from one ethernet port or WiFi.
Might be worth considering.
greenamex2
Postby Stephen Dean on Tue Aug 06, 2024 10:42 am
I use a Switch like this in my car. It runs off 5V/0.6A so I have made a power cable with the correct two pole power connector at one end, and a USB 2 connector at the other. This allows me to power the switch from the USB port that I have in the car.
Return to MoTeC PC Comms
