Hi John,
Across all the PC's in our office we are unable to reproduce the issue you are experiencing of the value failing to update.
When scaling is set to a value other than 100%, this does lead to performance issues for some elements of i2 pro. The same can be said for Application DPI settings
Outside of the time graph, items in the task bars and drawing for the worksheet tabs are rendered by windows, whereas components, track map headings, report tables, data and value views all have the font and font sizing controlled in i2 under Tools > Options > Fonts
- Rescaling - resized.png (308.66 KiB) Viewed 2525 times
I2 is not a DPI aware program and at this stage there is no plans to try and implement that functionality with the nature of the software (dots and lines) this would be a large body of work to implement.
A typical behaviour is that the time/distance values are slow to update. On my previous laptop (4k resolution screen 150% scaling) if i was to drag the cursor across the time graph, it would update the time and distance values at around 1hz, instead of real time. On my current machine (4k resolution 125% scaling) with more modern hardware i have no change in performance.
As it is not something we can influence in the software (we determine the values, this data is then passed to windows to render which is where a render delay or in your case failure to draw at all) all we can suggest is that:
- you check your direct x drivers are working and up to date (run dx diag):
https://support.microsoft.com/en-au/win ... 92228dfd85- if your PC has a discrete graphics card, you may have better results ensuring that the discrete graphics card is used for any rendering of i2:
https://www.asus.com/au/support/faq/1044213/Regards,
Nathan
