E 888 can speed 500kb to 1mb
Includes expansion units, sensors, valves, wiring, communication cables etc.
Postby MyRaw on Fri Jun 21, 2024 5:53 am
Good morning,
I'm using an E888 but it only works with can line speed
500kb.. is it possible to change to 1Mb?
Thank you
MyRaw
Re: E 888 can speed 500kb to 1mb
Postby SOReilly on Fri Jun 21, 2024 9:21 am
The CAN bitrate of the E888 is set in the firmware and cannot be updated in field.
This change can only be performed at MoTeC as the firmware has to be resent to the E888.
If you want the firmware to change the bitrate from 500k to 1M you will need to organise an RMA through your MoTeC dealer.
SOReilly
Return to Accessories and other MoTeC products
