MOTEC ADL and ATL Fuel Level
Postby RSeq86 on Sun Apr 21, 2024 8:57 pm
Hi mates,
I have an ATL Fuel Level Sender (240Ω - Empty to 33Ω - Full) with gauge and I want to connect the signal to Motec ADL to Fuel Level channel.
Do I just need to connect the signal wire between the Sender and the Gauge like this diagram that I send attached, or do I have to do some resistance pullup?
The Sender has a 12V power supply and ground.
Thank You.
MOTEC - ATL Scheme.jpg (43.97 KiB) Viewed 7162 times
RSeq86
Re: MOTEC ADL and ATL Fuel Level
Postby Stephen Dean on Mon Apr 22, 2024 10:49 am
Is there a datasheet for the sender?
Postby RSeq86 on Mon Apr 22, 2024 6:33 pm
Thanks for the quick response.
Attached is the data sheet for The ATL EL-AD-151 (Resistance Output).
ATL datasheet.jpg (326.5 KiB) Viewed 7123 times
RSeq86
Postby RSeq86 on Wed Apr 24, 2024 6:39 pm
any help please?
RSeq86
Postby Stephen Dean on Fri Apr 26, 2024 11:06 am
Wire this into a free AV input on the with a pullup to 5V through probably a 220 ohm resistor.
Postby RSeq86 on Sat May 18, 2024 6:27 am
It works well if I connect the probe signal only to the MOTEC ADL but if I also connect it to the gauge it no longer works.
Is there any way to have the pressure gauge and the MOTEC ADL work together?
RSeq86
Postby Stephen Dean on Mon May 20, 2024 10:42 am
No knowing how the gauge works, I would assume that it is either pulling the signal down to ground, or putting voltage onto the signal wire, either of which will stop the sensor from displaying correctly on the ADL. You would need to monitor the voltage seen by the input pin to know what it happening.
Return to ADL, ADL2 and SDL
