Compatible M800 SI Throttle Valves (Diameter: 50 mm)
Postby VolvoPenta on Fri Apr 05, 2024 7:38 pm
Hi everyone,
I've come across information suggesting that not all SI throttle valves are compatible with the MoTeC M800. Can someone please clarify the specific requirements? Additionally, could someone provide one or more examples of an SI throttle valve (normally closed) that is compatible with the MoTeC M800 and has a diameter of approximately 50 mm?
Thanks in advance!
VolvoPenta
Re: Compatible M800 SI Throttle Valves (Diameter: 50 mm)
Postby Stephen Dean on Mon Apr 08, 2024 5:59 pm
Hi, Most modern DBW throttles can be used with the M800, I would recommend the Bosch throttles if you are sourcing one.
