Greetings all.
We are using a M130 ecu, AIM solo 2 DL, and a LTC-D. The firmware is based off motorcycle drag and Motec USA has done all the build changes for us to date.
We have been using the same communications templates for over a year with no problems.
We added a Gripone IMU to the can bus, and Motec USA built it into the firmware. There are no issues seeing the output from the IMU in the ecu and (Motec) recorded data. The IMU is transmitting on 500, 501, 502 and receiving on 480.
I have done a caninspector capture and can see all the IMU messages when it is plugged in. There is nothing else using that address that I can see.
When the Gripone IMU is connected some of the channels displayed on the AIM dash drop in and out every 3-4 seconds. Not all the channels, only coolant temp, ecu voltage, oil temp, and both lambda channels. All these are still working fine internally in the ecu and logged data.
The AIM solo 2 is exporting GPS and G-meter data to the ecu and these drop in and out also when the IMU is plugged in. So some of the channels ecu>dash are dropping out, but all of the data dash>ecu is dropping out.
Pic below is screen shot from G-meter showing drop out.
I have attached the can inspector data as well.
Both AIM and Motec USA have looked into this and are telling me it's on the others side.
Any input would be much appreciated!
