by VERMotorsports on Wed Mar 13, 2024 10:27 pm
Injectors are wired right as far I can tell using a multi-meter and chasing wires, we managed to test it like follows, since cil2 is misfiring, we connected an external injector to the connector, and got it pulsing, so I figured it workings, just doesn't want to work in test mode.
Now I found out that even though its a wasted spark system, its firing right for cil1-4 but the 2-3 is having issues, the #2 coil isn't firing at the right time, which is weird since its supposed to fire at the same time as #3.
This car is making me crazy, diagnostic tests don't give back the right results yet stuff seems to fail.
Same story as the injector, if you run the car and pull the spark plugs cables out, both #2-3 have spark, but seems like its not firing at the right time. I will try to upload a log, we are in a hurry, tomorrow the car needs to leave for the first race of the year, and I can't get it to run in 4cyl properly for the time being.
BTW using the osciloscope we found out the ignition output for #2-3 is missing a cycle
PS: Let me add some more info, so I chased the wires for ignition, in the cfg its output 1-2-3-4 for ignition, yet on the back side of the 34pin connector, I found that the 1-4 outputs are wired together, and the 2-3 the same, don't know why someone would do that, instead of just wiring the 1 and 2 and put in the cfg both cil1-4 as output 1 and 2-3 as output 3.
Also since the coil doesn't have a driver, who ever wired this is using the OEM ECU as a ignition driver module, what a piece of....
Is it possible to use a coil without an integrated ignition driver on the M130??
If not, can I use any ignition driver with it?
- Attachments
S1_#333_20240313_084324.ld
- (3.04 MiB) Downloaded 1349 times
S1_#333_20240313_084324.ldx
- (285 Bytes) Downloaded 1176 times
