Stephen Dean wrote:Hi,
If I recall correctly, the Non VVT equipped 2JZ engines used a 12 tooth crank trigger with a single sync tooth on the Cam, so this will use the Multi Tooth Four Stroke Reference Mode with 12 set for the Engine Speed Reference Tooth Count. You will need to do an Input Capture to set the Sensor type and Edges in use.
As for the remained of the setup, all of the 2JZ Packages that I have seen use different sensors, coils and injectors from the OEM, so there is not a base Package that can easily be used to start with
I do not have a validated number for this with the 12 tooth trigger, looking through the non VVTi Packages that I have access to shows a value around the 390° mark as a starting point.
