DBW M800 TB Settings
Postby oficinademotores on Tue Jan 30, 2024 3:52 am
Hello, is it possible to obtain the calibration of this throttle body?
Thank you
BOSCH 0 280 750 085
oficinademotores
Re: DBW M800 TB Settings
Postby Stephen Dean on Tue Jan 30, 2024 8:59 am
Data attached, The greyed out areas are not needed.
Bosch 0 280 750 085.png (18.63 KiB) Viewed 2989 times
Postby oficinademotores on Fri Feb 02, 2024 2:38 am
Hello, thank you for your attention.
I have the Bosch 0280750081 throttle body with the adjustment provided by you, I have tried the Bosch 0280752251- 4 pin and Hella 6pv00908304- 5 pin gas pedal and I cannot configure the DBW.
I follow all the instructions in DAD0001 Drive by Wire_Electronic Throttle Setup.pdf, but I don't know where I'm going wrong.
Thank you
oficinademotores
Postby Stephen Dean on Fri Feb 02, 2024 10:01 am
The forums is not the best place for this sort of question. Do you have a local MoTeC Dealer? These sorts of issues really need to have live interaction with the ECU to determine the cause of the issue.
Postby oficinademotores on Sat Feb 03, 2024 2:15 am
Hello, well, sir. Thank you very much for your attention. I have managed to solve the problems caused by pedals that are not compatible with the M800.
Thank you
oficinademotores
Users browsing this forum: No registered users and 33 guests
