Newbie, please be kind - Sync lock issue M130
Postby justineurope on Tue Jan 23, 2024 7:25 pm
Hi Motec world, I'll preface my question by saying I'm a newbie, I have done a fruitless search, but my terminology as a newbie may limit a search efficacy. I'm also broke so paying for the answer is not an option. Im in SA Australia
I've got an M130 on a Suzuki M series engine with VVT. Wiring appears to be working as a trace of a cranking process appears to show the tooth patterns expected (Mazda Mx5 2006, which is what the engine speed reference mode is set too) While cranking I get pattern lock but never achieve cycle lock and as such neither the injectors or spark fire (an ignition test proves the wiring will trigger a spark on the correct cylinder as does an injector test.) the Engine speed reference Offset has been confirmed by two other sources, 1 running a similar engine (different ecu brand) and the Shhh... Haltech site (sorry)
I would like to get the thing close to or actually idling before engaging a tuner (read I'm broke) (plus I hate to be beaten).
Im assuming its a simple tick box badly ticked or incorrectly entered value somewhere but the Motec is not simple, but I feel I may be!
Any advice greatly accepted.
Id also post snips of the M1 tune pages and the trace if I could work out how to on this forum. Advice also sought if it helps.
Please help. JP
justineurope
Re: Newbie, please be kind - Sync lock issue M130
Postby Stephen Dean on Wed Jan 24, 2024 8:58 am
Can you do a Input Capture and post it and the Package file (use the Export function for both). Logging of the engine cranking with the txt file that is generated would also assist. With the logging, if you can clear the existing logging out before you attempt to start the engine so that the file only shows the cranking attempt makes it easier.
Postby moylee19 on Wed Jan 24, 2024 11:28 am
Motec CDL3 - M130 -LTCD - PDM15 - Keypad
Suzuki GTi IPRA Car
moylee19
Postby Stephen Dean on Wed Jan 24, 2024 12:28 pm
Screen captures do not help, you will need to provide the information requested to allow for us to assist you. Otherwise, the MoTeC Dealer that sold the hardware to you should also be providing assistance in getting your engine running.
Stephen Dean wrote:Hi,
Postby justineurope on Thu Jan 25, 2024 10:51 am
Hi Stephen,
thanks for the help, screen capture was a mate not me, thanks Simon!
Here is What I think are what you need. input capture export (archive) and the Package export (Archive)
_New Capture 4_ M130 #9293.m1inc-archive
input capture
(104.42 KiB) Downloaded 632 times
I believe I cleared all logged data before creating the new one.
As for a TXT file, how or where is this created or where can I learn how to create it.
Hope this is what you asked for an need.
JP
justineurope
Postby Stephen Dean on Thu Jan 25, 2024 11:30 am
Can you download this file and extract it by double clicking on it.
Once you have done this, can you then connect to the M1 using M1 Tune and go to File | Override ECU System Version... and select System 01.04.00.0093 from the drop down list. When you click OK, you will be prompted to Save the changes and then resend the Package into the ECU, do this by clicking on the Send icon.
Try starting the engine again, and see if the issue remains.
I have also migrated your Package to the latest version and included the latest license file for your M1. I have changed some of the settings to suit your vehicle.
GPA (M130) [01.11.0159, July 2019] Widebody Swift v2.0 , MoTeC 301223.m1pkg-archive
(2.15 MiB) Downloaded 681 times
Licence for M1 9293-2.m1lic-archive
(7.66 KiB) Downloaded 501 times
01.04.00.0093.m1sys-archive
(1.27 MiB) Downloaded 725 times
Postby justineurope on Thu Jan 25, 2024 1:06 pm
Thanks Stephen, I still only have pattern lock, not achieving sync. What did you change?
Justin
justineurope
Postby Stephen Dean on Thu Jan 25, 2024 2:52 pm
Where is the Camshaft Position sensor wired into? Universal Digital 2 or Universal Digital Input 4? If I disable the Engine Synchronisation Resource (UDig 2) in your Package, and run the Cam Position signal into UDig 4, I get Cycle Lock. Can you disable the Engine Sync Resource by going into Tools \ Edit Input/Output Resources... and setting the Engine Syn Resource to Not in Use. This will require the M1 to be restarted to effect the change. If this still doesn't get Cycle Lock, can you do another Input Capture, ensuring that UDig 4 is also captured.
Postby justineurope on Thu Jan 25, 2024 3:29 pm
Hi again,
Camshaft position was wired and assigned to UDig 2. Udig 4 piggybacks this signal and is assigned (hopefully) to VVT position sensing.
I have attached the capture with Udig 2 disabled and UDig 4 on (inlet Camshaft Bank 1 position [V]
_New Capture 5_ M130 #9293.m1inc-archive
(143.6 KiB) Downloaded 646 times
Thanks again
Justin
justineurope
Postby Stephen Dean on Thu Jan 25, 2024 4:09 pm
I have assigned Udig 2 to the Inlet Cam Bank 1 Resource in this Package, the signal should not be split so remove the wire into Udig 4. This Reference Mode does not need a Sync input allocated as it uses the Inlet Cam Position for Synchronisation.
GPA (M130) [01.11.0159, July 2019] Widebody Swift v2.0 , MoTeC 250124.m1pkg-archive
(2.15 MiB) Downloaded 813 times
