Toyota 86 2012, visconti flex fuel fron O2 B1S2
Discussion and support for M1 Plug-In ECUs
Postby nobletech on Wed Jan 17, 2024 1:38 am
I have a ft86 customer who wants flex fuel, the visconti sensor is already in the car and plugged in and powered by sensor 2 of bank 1.
is there a clear path to using the FT86 package we have installed to read these values from this connector?
should I swap some pins at the ecu connector to get into the M150?
or
should I just wire it into the supplied spares connector?
or suggestions?
Thanks, Troy
sorry about the image size. do not have ability to reduce size do to lack of knowledge
O2 wiring.png (148.94 KiB) Viewed 2148 times
nobletech
Re: Toyota 86 2012, visconti flex fuel fron O2 B1S2
Postby SOReilly on Wed Jan 17, 2024 8:41 am
Hi Troy,
The Toyota 86 package has flex fuel support within the Alternative Fuel subsystem.
The fuel composition sensor will need to be wired to any available UDIG input, once you have the sensor wired and configured the attached guide should explain the tuning process.
M1 Flex Fuel User Guide.pdf
(868.71 KiB) Downloaded 294 times
SOReilly
Return to M1 Plug-In ECUs
