JRR Piggyback on Huracan
Postby TurboTim on Mon Jan 08, 2024 1:52 am
I purchased a Huracan that I thought had the actual Motec kit but it has a JRR Motec setup as a piggyback on it instead that controls a 3rd set of injectors. This Motec is PW protected. I would like to change the tune for bigger turbos but I am not sure what to do. If I sent this back to Motec and they unlock it are they able to get a firmware to run it or is anyone else able to?
TurboTim
Re: JRR Piggyback on Huracan
Postby Stephen Dean on Mon Jan 08, 2024 2:05 pm
The Password can be removed, the process to do this also removes the Firmware from the M1. When a password is reset, the Firmware is reset back to the base file as found on MoTeC Online. Any tuning and/or configuration work that has been done to this point will be lost.
Postby TurboTim on Mon Jan 08, 2024 10:10 pm
I am guessing there is no base file for a Huracan setup as a piggyback. How hard would it be to get or make this basefile?
TurboTim
Postby TurboTim on Mon Jan 08, 2024 10:32 pm
How hard is it to get a firmware to run a Huracan setup as piggyback?
TurboTim
Postby TurboTim on Tue Jan 09, 2024 12:28 am
How hard is it to setup a firmware to run the Huracan as a piggyback?
TurboTim
Postby TurboTim on Wed Jan 10, 2024 2:52 pm
Do you have a firmware that will work for it as piggyback? Is it hard to create such a thing?
TurboTim
Users browsing this forum: Google [Bot] and 16 guests
