MDC 500k inside
Discussion and support for MoTeC's Mitsubishi and Subaru Diff Controllers
MDC 500k inside
Postby gkafe on Wed Dec 20, 2023 10:39 am
Hello
On a recently boughted Evo 8 Gr N there is a problem with the mdc it is constantly flashing
The ecu is m800 with last firmware, comunication is fine.
With mdc I have not comunication
The mdc writes on the box (attention 500k inside) Does it means the communication speed is 500kbps?
Do someone knows if there are is different can bus speed on older MDCs?
Thank you!
gkafe
Re: MDC 500k inside
Postby NathanB on Wed Dec 20, 2023 11:51 am
Are you using an M800 pnp or a standalone gold box?
Is the M800 can bus speed set to 1mb or 500k?
Re: MDC 500k inside
Postby gkafe on Wed Dec 20, 2023 8:21 pm
The car made 15 years ago and I think the problem started after m800 ecu upgrade
Is GrN and use PnP m800 and Original wirring
In the ecu comunication/ can setup is enabled only can 0
CAN 0 data = 1
Can 0 Address = 1520
Can0 transfer rate =50 ?
What Address and seting is needed to Pnp MDC?
On the Mdc there is a different connector but I have no any comunication
the car made 15 years ago and I think the problem started after m800 ecu upgrade
Thank you!
gkafe
Re: MDC 500k inside
Postby Stephen Dean on Thu Dec 21, 2023 10:25 am
I have attached the installation notes for the EVO8 Plugin and the MDC.
MDC User Manual.pdf
(227.98 KiB) Downloaded 736 times
DVIN0011 M800 OEM to Mitsubishi EVO8.pdf
(222.79 KiB) Downloaded 535 times
DVIN0007 Mitsubishi M800 OEM EVO48 Installation Notes.pdf
(224.16 KiB) Downloaded 508 times
Return to MDC and SDC
