by Stephen Dean on Wed Nov 01, 2023 9:07 am
I have attached a Input Capture from a Early EJ207 that uses the EJ207AVCS Reference Mode, as this has cams with 4 equally spaced teeth and Mag sensors. You have a 4-1 tooth pattern on your cams, which is used in the FA20D Reference Mode. You can disable the Sync input and just use the Inlet Cams.
- Attachments
Test M150 #1598.m1inc-archive
- (204.79 KiB) Downloaded 948 times
