Subaru 2007 Ref Sync needed
Re: Subaru 2007 Ref Sync needed
Postby ammar.alqisie30 on Mon Oct 30, 2023 9:30 pm
3 Captures attached, which one looks good ?
Capture V3 ( On, Raising ).m1inc-archive
(428.97 KiB) Downloaded 891 times
Capture V2.m1inc-archive
(393.19 KiB) Downloaded 976 times
Capture V1.m1inc-archive
(411.25 KiB) Downloaded 468 times
ammar.alqisie30
Postby Stephen Dean on Tue Oct 31, 2023 9:04 am
Capture three is showing the correct signals and voltages. The Inlet Camshafts are on UDig 4 and Udig 5 in the capture.
Postby ammar.alqisie30 on Tue Oct 31, 2023 9:15 am
Sounds good, it should be raising , pullup on?
And whats the correct offset and calibration?
ammar.alqisie30
Postby Stephen Dean on Tue Oct 31, 2023 11:25 am
I would use the settings for the MY08+
Subaru FA20D Reference Mode.png (198.43 KiB) Viewed 6055 times
Postby ammar.alqisie30 on Wed Nov 01, 2023 8:44 am
We used the setup you sent, it keeps giving bad sensor.
Engine is 2007 not 2004. We use the front cam as Engine synchronization pin and the rear for cam inlets bank 1 and bank 2,
I saw some people saying we should use the synchronization pin on back on of them.
Car is runing fine, but problem with AVCS .
Camshafts teeth of 2007 is different with 2004
Any advice? .
ammar.alqisie30
Postby Stephen Dean on Wed Nov 01, 2023 9:07 am
I have attached a Input Capture from a Early EJ207 that uses the EJ207AVCS Reference Mode, as this has cams with 4 equally spaced teeth and Mag sensors. You have a 4-1 tooth pattern on your cams, which is used in the FA20D Reference Mode. You can disable the Sync input and just use the Inlet Cams.
Test M150 #1598.m1inc-archive
(204.79 KiB) Downloaded 948 times
Postby ammar.alqisie30 on Wed Nov 01, 2023 4:49 pm
Attached your capture with our capture to compare, the capture on cam inlets is different.
Check the captured pictures we attached .
Capture c2.PNG (36.84 KiB) Viewed 6026 times
Stephen Capture
Capture c1.PNG (40.62 KiB) Viewed 6026 times
ammar.alqisie30
Postby Stephen Dean on Wed Nov 01, 2023 5:01 pm
That is correct, My Capture uses the EJ207AVCS Reference Mode with the four evenly spaced Inlet Cam teeth and Mag sensors. Yours uses the FA20D Reference mode with the 4-1 Tooth pattern and Hall sensors.
Postby ammar.alqisie30 on Wed Nov 01, 2023 6:56 pm
So, should we change the Engine speed reference mode to FA20D ?
ammar.alqisie30
Postby Stephen Dean on Thu Nov 02, 2023 8:47 am
Yes.
PreviousNext
