The most under utilized M800 install ever?
Postby Ben-S on Thu Apr 30, 2009 8:36 am
Powering a single injector flow bench :mrgreen:
Since the photo's I've switched to a scale accurate to .1g instead of the graduated cylinder. Its run by my M800 and laptop (laptop simulating engine sensors through printer port) I will most likely slowly update this to log everything through the ecu including fuel weight, temp in, temp out, pressure, and dead time (along with all the other obvious injector parameters that are already logged)
My current thinking is a strait gauge and a platform with a bottle on it some simple calibration should be able to turn that into a scale unless anyone has a better idea, i'm really hoping there is a 0-5v scale out there.
Ben-S
Re: The most under utilized M800 install ever?
Postby Scott@FP on Sat May 02, 2009 6:35 am
Is there a reason you use sensor foolage instead of just going into actuate outputs and setting a PW and DC%/RPM for that inj output?
Scott@FP
Postby Ben-S on Sat May 02, 2009 1:42 pm
I assume you mean test outputs? If that's what your referring to then yes there are many, the biggest of those reasons being that I wouldn't be able to datalog anything.
Ben-S
Postby MarkMc on Tue May 05, 2009 11:49 am
Ha, that's nothing,
Our injector flow bench has an M800 and an ADL for two injectors.
Postby Ben-S on Thu May 07, 2009 5:43 am
damnit i only have an SDL... if only i could figure out something to use my E888 for :D I do have an oscilloscope on there now too but i guess with the sample rate of an ADL you probably don't need that.
Do you mind telling how you measure flow (is it logged somehow)
Ben-S
Postby RossB on Thu May 07, 2009 9:44 am
We don't measure the flow, we use the test output function on the ECU to flow the injectors at various opening times (at 6000 RPM) and the timer in the ADL to run each test for 1 minute. We then weigh the calibration fluid on a very acurate set of scales and calculate the flow from the weight.
RossB
Postby C4a0s on Thu May 07, 2009 11:18 am
its like using a 360 modena to go to the nearest bookshop for a pencil... :mrgreen: :mrgreen: :mrgreen:
you could always send the ADL to me if you have no use for it :lol:
C4a0s
Postby Ben-S on Thu May 07, 2009 1:10 pm
That's how I'm currently doing it, I was hoping you figured out a way to log the scale reading
Ben-S
Postby Holmz on Thu May 07, 2009 6:19 pm
This is a pretty slick set up.
I would think that you could also measure the dead time pretty accurately.
Holmz
Postby AaronM on Thu May 07, 2009 10:58 pm
Hi guys,
Are you doing this to test the accuracy of the ECU with different injectors (inc dead time), check the flow rates of injectors or to set the ECU up to monitor fuel usage for circuit racing?
AaronM
Users browsing this forum: Google [Bot] and 46 guests
