Having some trouble setting a good boost control using a 3 Port MAC boost solenoid and JRR Firmware..
Under boost control menu, I set all PID's to 0, and manually tuned/setup the Boost Target and Feedforward Tables, when I go above 1.4 bar at around 5500rpm and 6200rpm the boost fluctuates 0.2bar above and below target..
Set the frequency from 10Hz to 40Hz and nothing changed.
If I replace the MAC EBS(I tried 2 MAC's) with a manual boost control valve, boost is steady across the rpm range.
Shouldn't boost be steady if all PID's are set to 0 or is it mandatory to also tune the PID tables to get a stable boost line ?
Kam
