In the HPA webinar Tuning Dual VVT they showed a setup that ramped the cam through the travel range with an increase of 1 deg/s on a steady state dyno run.
Is this a function available in M1 Tune?
MalcolmG wrote:Do you have the ECU Receive set up in the M1 as a Sequential or Compound type? The dash manager configuration you've screenshotted is for a compound setup, which IMO is unnecessary until you're really short on available CAN addresses. If you're not aware, compound messages effectively multiplex a single CAN address by using the first byte (typically) of the message contents as an additional identifier, with each compound identifier having different data content on the remaining message bytes.
I recommend using a sequential messaging, which just uses a sequence of 8 CAN addresses beginning from the start address (make sure the start address is a multiple of 8). To use this you just configure each message individually as Transmit Message type rather than Transmit Message Block. If you look at the built-in GPS_to_M1 transmit templates in dash manager you'll see how this is achieved
