Motec M800 with PDM15
Postby ammar.alqisie30 on Tue Jul 04, 2023 7:46 pm
We have a EVO X with M800 ECU and PDM 15, we have an issue with CAN Setup, We need to make the Fans working on PDM related ECT on ecu .
So any idea about the CAN Setup on ECU & PDM .
ammar.alqisie30
Re: Motec M800 with PDM15
Postby Stephen Dean on Wed Jul 05, 2023 10:34 am
The attached PDM file has the M800 receive channels that you need in it, this uses the standard M800 transmit data.
M800 PDM CAN.pdm
(25.27 KiB) Downloaded 962 times
Postby ammar.alqisie30 on Fri Jul 07, 2023 3:43 pm
Thanks Stephen, i got it .
Should we do anything on ecu ( Can Setup ) ?
And how we can activate ALS from keypad ? Keypad connected to PDM, whats the can message ?
ammar.alqisie30
Postby Stephen Dean on Mon Jul 10, 2023 10:17 am
I don't have a setup that I can test with at the moment, but as far as I am aware it is not possible to use CAN switches into the Mx00 series of ECU's.
Postby super7 on Tue Jul 11, 2023 5:49 am
Stephen Dean wrote:I don't have a setup that I can test with at the moment, but as far as I am aware it is not possible to use CAN switches into the Mx00 series of ECU's.
A long shot.
It is not possible to activate an output on the PDM that has been connected to an input on the M800
super7
Postby Stephen Dean on Tue Jul 11, 2023 10:24 am
That can be done.
Postby cotje on Sat Feb 10, 2024 7:10 am
If have ORB setup working with the Keypad/CDL/M800 combi. Keypad can send data to the CDL and CDL forwards it to the M800. Some conversions were needed to make it work, but with one key I can now go through ORB off/1/2 settings. Works awesome!
Same for different boost-settings btw!
cotje
Users browsing this forum: No registered users and 40 guests
