Hey everyone, I know it's pretty dead in here and this hardware is old enough to buy alcohol... But figured I'd give it a shot. I just bought a 1990 RX-7 with a motec M4. I downloaded M4 EMP V6.20D, and it gives an incompatible software error. So then I downloaded 6.13 and it tells me that the ECU has 6.2 software. I'm not sure if there's an experimental build that has been forgotten or some way to force communication without losing the tune and starting from scratch.
Any help? Here's the message I get with 6.20D:
"INCOMPATIBLE SOFTWARE
The ECU software is the correct version but is not compatible with the PC software
The ECU software may be a special version
Update the ECU software or use the correct version of E.M.P."
