Cumulative total from log file
Postby jwickman on Wed Jun 14, 2023 9:01 am
Hi all,
is there a way to create a maths channel that adds the cumulative total of a channel i.e. fuel used across multiple start / stops of the firmware in a single log.
Cheers John
jwickman
Re: Cumulative total from log file
Postby MalcolmG on Tue Jun 20, 2023 1:11 pm
If you're using i2 Pro, you can take the derivative of the channel, then integrate the derivative except any time that the derivative is negative. Make sure you set the calculation rates to the same frequency and it should give you what you're looking for.
E.g:
accumulator result.png (17.31 KiB) Viewed 4834 times
MalcolmG
Postby jwickman on Thu Jul 06, 2023 12:37 pm
Hi Malcolm,
Unfortunately im not using the Pro version. Im guessing i need the advanced maths functions to be able to do this.
jwickman
