PDM30 Porsche 911 Safari Wiper High Speed Issue
Postby impLODE on Sun Jun 11, 2023 4:43 pm
Hello, I am having some trouble with the High Speed Wiper setup on a PDM30 for a Porsche 911 Safari.
Low Speed Wiper works fine, the wiper parks everytime.
I have linked the outputs 9 & 10 in the software but when turning Wiper High ON, the amp draw spikes to 20amps and after a few cycles, the output turns off.
I have observed the Wiper Brake Switch goes active High (0>1) at above 11V but I am not able to find the right settings to allow Wiper High Speed to run continously.
Is there any tips at finding the correct setting, so far I have been changing Channel True and False voltages trying to find the right value but after a number of attempts I am starting to doubt this is where the issue lies.
File atttached has the current settings that I am using for Wiper Low, High and Wiper Brake.
911 Help.pdm
(27.2 KiB) Downloaded 12145 times
impLODE
Re: PDM30 Porsche 911 Safari Wiper High Speed Issue
Postby SOReilly on Tue Jun 13, 2023 10:50 am
If you are drawing in excess of 20A on output 10 it is likely going into over-current protection.
You will need to measure how much current the high speed motor is drawing in operation as 20A sounds excessive.
If the wiring is undersized or there is a bad connection causing high resistance this could cause the current to exceed the max setting and the PDM will disable the output.
SOReilly
Postby GWRMOTORSPORT on Wed Jun 14, 2023 9:01 am
Hi impLODE
assuming you have a version 2 hardware PDM and that the park switch goes to ground to park, the usual way most wiper motors park by generative braking, the attached pdm file should help, Also make sure that the wiper switches are working independently of one another, i;e when switch 1 is grounded switch 2 isn't and vice versa.
I would also disconnected the switched 12v to the motor so your only left with,
SLOW from PDM output 9, Pin A2
FAST from PDM output 10, Pin A4
PARK to PDM input 2, Pin A19
GROUND, a good chassis ground
Hope this helps
Steve
GWR Motorsport
911 Help V2.pdm
(32.2 KiB) Downloaded 19625 times
GWRMOTORSPORT
Postby impLODE on Sat Jun 17, 2023 1:44 pm
Hi Steve,
I will double check the ground and see if this wiper config works out for me.
Many thanks for the help, I will update the thread with the results once I get back to the car.
Cheers!~
impLODE
Postby impLODE on Mon Jun 19, 2023 3:10 am
Hi Steve,
The test didn't workout with the proposed settings, the wiper would no longer park after switching off the low speed wiper setting and there was no difference to the high speed wiper problem I am facing, Wiper High runs for a while until it exceeds the Load retry count and the PDM output will shut off.
1. The Wiper "Parks" when the Wiper Brake Switch is High - screenshot attached.
With the Wiper Brake Switch setting as High, the wiper properly parks every time from no matter which stage of the wiping it is at when the wipers are turned off so I think this setting is good.
2. When testing the PDM Outputs independantly, The Wper High still exceeds the Amp draw of Output 10.
I will try a different grounding location.
Additionally, the wiring on the PDM Ouput side is exactly as you have suggested however I will recheck if the Wiper Low Switch is actually switched off while the WIper High Switch is switched on.
Wiper Brake Switch High
911 Help.jpg (331.84 KiB) Viewed 96282 times
impLODE
Postby GWRMOTORSPORT on Mon Jun 19, 2023 9:19 am
Hi
just wondered whether your motor is the 3 speed one with the resistor on the side,
the drawing below shows the circuit, PDM wont do 3 speeds. it will need relays
Hope this helps
regards
Steve
GWR Motorsport
Porsche wiper circuit.jpg (7.88 KiB) Viewed 96266 times
GWRMOTORSPORT
