Hi
New to the M130 and looking for some advice on outputs.
Which output is best used for the tach signal ( standard square wave output) ? in the GPA package I have its set standard on a 1/2 bridge output.
Having used up all LS Injector and LS Ignition outputs can I use PH to drive a relay coil ?, I understand 1/2 bridge is not good option ?
Many thanks
