Help with DBW pedal
Help with DBW pedal
Postby ZT-R on Mon Mar 27, 2023 12:42 am
Hello
I have a M150 and have this pedal BDBW-GM06
Lokar
https://www.lokar.com/throt-assemb-pedal-pads.html
All GM Crate Engines, '08-'12 Cadillac CTS/CTSV, and '10-'12 Camaro #10379038, #10367117, #22741799, #22741800, and #92199239
https://www.lokar.com/assets/instructio ... ByWire.pdf
The number on the Sensor is Williams Control 134734
I think this may be a data sheet for it but im not sure. the works on the Apps side but not the other 3 wires. but this is beyond me as well.
https://www.cw-industrial.com/getmedia/ ... t?ext=.pdf
ZT-R
Re: Help with DBW pedal
Postby Stephen Dean on Mon Mar 27, 2023 8:44 am
That Williams control setup is not acceptable for a DBW pedal as it only has a single sensor output. The Lokar one can be used.
Postby ZT-R on Thu Mar 30, 2023 12:07 am
Thre lokar one is what I bought (GMO6) and the senor that is on the side of it is the Williams.
ZT-R
Postby David Ferguson on Thu Mar 30, 2023 4:15 am
Your Williams Controls data sheet is not for the sensor as programed in the Lokar pedal. I am trying to get you the correct data sheet, but I would think you could go with the info in the Lokar instructions -- that indicates it should work with the MoTeC DBW Pedal setup,as there are two analog voltage outputs.
Postby David Ferguson on Thu Mar 30, 2023 5:06 am
I couldn't get a complete data sheet as the outputs are programmed for different customer requirements, but here is the pinout for 134734 that clearly shows two APS outputs.
Williams Controls 134734 pinout.png (34.25 KiB) Viewed 4761 times
Postby ZT-R on Mon May 01, 2023 11:01 am
That got it, thank you sir!
ZT-R
