A bit of a simple question that I cannot find a straight answer for. I have a Porsche 964 that uses a VR sensor and missing tooth flywheel together with a separate hall sensor.
In my previous ECU setup I pulled a ref+ and ref- signal straight to the ECU together with a shielded cable.
In the M150 documentation and M1 tune it seems to me like I only need one signal to the UDIG1 and then pull the hall sensor to UDIG2.
Where does the second wire from the VR sensor go or alternatively what have I missed? It feels odd to simply ground the second wire and then on top of that also shield it.
Would be great with some help on this!
