Trying to clarify something here:
If I want to read lambda on address 0x651 / bit 0 - I have to also integrate the Motec Lambda-to-CAN-module, correct?
The rep I emailed with just said "confirm with customer if lambda is sent"...
thank you!
David Ferguson wrote:The firmware in the M1 has to have a working Lambda value to send something on 0x651. This could be an LTC connected to the same or different CAN bus, or something else depending on firmware.
David Ferguson wrote:Yes, the GPR firmware will only work with the MoTeC CAN-connected Lambda Controllers (LTC or PLM). The GPR firmware on the M150 will use the Lambda value info it receives over the CAN bus to provide the "Exhaust Lambda" channel that you see broadcast to CAN Addr 0x651, Byte 0 on the ECU selected CAN bus.
David Ferguson wrote:Well, it could be on the same bus, but you have no control over that. Customers may wire their cars with all the engine bay stuff on one CAN bus, and all the cockpit stuff on another -- it should not be too hard it get your low-level driver fixed -- do that instead of working on "hacky" solutions. In looking at your documentation, look for words like "silent mode" -- you don't want that...
Matce wrote:Trying to clarify something here:
If I want to read lambda on link address 0x651 / bit 0 - I have to also integrate the Motec Lambda-to-CAN-module, correct?
thank you!
