Hi all,
It appears that a recent update to Windows 10 has broken the installer for the Mx00 EMP, to get around this issue, use the following process.
the M84 EMP is not presently affected by this as it has been complied in a different compiler.
1. Press Windows Key + R and then type msconfig
2. In the system configuration window click the boot tab and then select the 'Safe Boot' tick box.
3. Click ok and windows will ask you to reset, click ok/yes.
4. When windows restarts install M800 ECU Manager, it should now work fine.
5. Once installed, repeat steps 1-3 but untick safe boot.
