Resource for an Lean Angel Sensor
Postby Ralle#67 on Mon Mar 06, 2023 12:12 am
how do I find the right CAN resource for a Lean Angel Sensor.
Can I just select a resource that is still free?
Best regards
Ralf
Ralle#67
Re: Resource for an Lean Angel Sensor
Postby Ralle#67 on Mon Mar 06, 2023 12:24 am
The Sensor is a Bosch MM5.10
Ralle#67
Postby David Ferguson on Mon Mar 06, 2023 5:04 am
What firmware package are you using? Does it have support for the MM5.10 implemented?
Postby Ralle#67 on Tue Mar 07, 2023 11:06 pm
Hello David,
I don't have a support under the point, so only a selection will be
from CAN 0 to 7 offered with different offset.
Ralle#67
Postby Ralle#67 on Wed Mar 08, 2023 12:05 am
Do I see that correctly when I'm under
Tools / Edit Input/Output Resources
simply select a free Can Resource?
Ralle#67
Postby David Ferguson on Wed Mar 08, 2023 12:17 am
Can’t help without knowing the pkg.
The GP pkgs have support for the Bosch ABS with I believe uses the MM5.10, however, they don’t calculate a lean angle from that data. The only sensors I know that do this are the TEXYS RAD6 and the GripONE, I have added support for those sensors on the past to custom Firmware pkgs I’ve created.
In my pkgs, you select the CAN bus the device is attached to, the specify the base address, finally you select a firmware resource base where the outputs go so you can use the information for various channels.
I suggest you contact the MoTeC partner that created your pkg for support.
Postby NathanB on Wed Mar 08, 2023 4:27 pm
Ralf,
Go to workbook 1: Main
Go to tab 5: All
In the search bar type : IMU
Under the IMU group there will be a Bosch MM510 - Set the Can Bus to Can Bus 1
Click on Message 1 and type 174 to set the ID to 174
Click on Message 2 and type 178 to set the ID to 178
Click on Message 3 and type 17C to set the ID to 17C
Now go back to the search bar and type Lean
Set the settings as follows:
Lean Settings.jpg (39.17 KiB) Viewed 6548 times
Now go back to the search bar and type: veh accel
Set as follows:
veh acceleration.jpg (115.5 KiB) Viewed 6548 times
Now go back to the search bar and type: roll
Set as follows:
roll settings.jpg (75.38 KiB) Viewed 6548 times
Now go back to the search bar and type: yaw
Set as follows:
That will cover you for the required setup of your Bosch IMU in your firmware.
Postby Ralle#67 on Thu Mar 23, 2023 8:35 pm
Hello Nathan,
thanks very much!
Ralle#67
Postby Ralle#67 on Mon Apr 24, 2023 2:01 am
I have now got the IMU and installed it.
I now get the error messages in the diagnosis of roll and yaw rate
Tramslation Minimun / Translation Maximun and Low Fault /
High Fault.
Should I now adjust the translation table to the values?
Also, do I need to set a zero position for the IMU?
Thanks very much
Ralle#67
Postby Stephen Dean on Mon Apr 24, 2023 10:25 am
Are the voltages seen by the M1 changing when the IMU is moved around, or are they staying the same?
