Can't edit start/finish on track map editor
Postby timlhunter on Tue Mar 07, 2023 1:01 am
Hi there,
for some reason I can't edit the start/finish line on track map editor. I am using the circuit workspace. Also the track configuration was no available in the data base. Any help is appreciated.
timlhunter
Re: Can't edit start/finish on track map editor
Postby Stephen Dean on Tue Mar 07, 2023 9:04 am
Hi Tim,
Which track are you using data from?
Do you have valid GPS or Beacon data?
Are you able to load a copy of the data here so that it can be tested?
Postby timlhunter on Tue Mar 07, 2023 1:22 pm
This was last weekend at buttonwillow configuration 27 CW.
I was using GPS and the map of the track generates, but it includes the hot pits as part of the track section. Also how do I go about getting a beacon?
I could only attach the ldx file ad the ld file is over 15mb. Is there another way to get it to you?
20230226-2735500.ldx
ldx file
(285 Bytes) Downloaded 1023 times
timlhunter
Postby timlhunter on Tue Mar 07, 2023 1:26 pm
https://1drv.ms/u/s!AqhjhILubfhAgbEDj8J15UbWZN6aag?e=q3CFD1
Above is a link to my share drive of the ld file
timlhunter
Postby Stephen Dean on Tue Mar 07, 2023 2:22 pm
Zooming in so that the bad GPS Data at the start and end of the file makes the maps draw correctly, I do not have the actual GPS data for the start finish of Button Willow so I placed the cursor on an approximate location and got this result when I generated the laps.
ImageGPS Data by Stephen Dean, on Flickr
Postby timlhunter on Tue Mar 07, 2023 2:29 pm
These are the coordinates for the start finish line 35.494680, -119.549606
How do I replicate the placing of the cursor in the i2 environment?
timlhunter
Postby timlhunter on Tue Mar 07, 2023 2:41 pm
Also the official race distance was1.830 miles
timlhunter
Postby Stephen Dean on Tue Mar 07, 2023 3:10 pm
In Tools | Lap Generator you can manually enter the GPS co-ordinate information into the options box, or you can place the cursor in the correct location using the GPS data in the logging and click the From Cursor button.
The attached ldx file should generate the laps for you if you load it in the correct location.
(2.26 KiB) Downloaded 976 times
Postby timlhunter on Wed Mar 08, 2023 1:43 am
When i go into Lap Generator on the original file, it gives me a message "No GPS data available"
How did you get it to work?
timlhunter
Postby David Ferguson on Wed Mar 08, 2023 2:56 am
He may have trimmed the file to eliminate the section with no GPS data.
