SDean wrote:Hi,
These units can be driven using a DHB to control the motor, the normal HB outputs do not have the current capacity (unless the operation of the gate is slowed down greatly) to drive this motor.
karel021 wrote:SDean wrote:Hi,
Hey any chance there will be a second boost servo to choose from ? or any other good way to setup 2 of these?
NathanB wrote:karel021 wrote:SDean wrote:Hi,
At the moment, there is no timeline to add a boost servo bank 2 option to any packages that do not currently support it. However, in place of using a MoTeC DHB, you could use a turbosmart Black box, which is intended to drive 2 boost servos on single output, which will suit parallel twin turbo applications.
ZT-R wrote:ability to control 2 gates yet? I'm a big single with 2 of them on split manifold.
