PWM output, how does it work?
Postby 07-EDM-STI on Sun Apr 19, 2009 4:19 pm
I've read that a stand alone ecu can be used to control water meth injection system, I don't know how the PWM works. does it work by pulsating the 12V output to control the meth pump? Can the PWM output of motec be connected directly to the 12V supply of the meth pump or does it need to be connected to a relay first to handle the high amp demands of the meth pump?? thanks in advance :)
07-EDM-STI
Re: PWM output, how does it work?
Postby IJ. on Sun Apr 19, 2009 5:17 pm
PWM>Solid State Relay>Pump.
IJ.
Postby 07-EDM-STI on Sun Apr 19, 2009 11:46 pm
IJ. wrote:PWM>Solid State Relay>Pump.
thanks a lot :)
07-EDM-STI
Return to M800 Plug-In ECUs
Users browsing this forum: Baidu [Spider] and 6 guests
