I have my engine tuned ok on steady state. No real lean spots and it runs good.
Fuel film works whell when running in gear.
Transient throttle situations with clutch pressed works flawless up to like 70-80% throttle. With 100% throttle input from 1000rpm engine cuts out completly at 5000rpm. Like its hitting an engine speed limit (which it don't).
This is a really responsive engine. Rpm rises really fast.
I have checked logs and can't see the engine management preventing it to rev. Lambda reads 2.5-3.0 so there is no combustion at all.
I have tried enriching the whole map at that area and it gives no response. Also tried some extreme numbers in the fuel film with no response.
I have not had this problem before and never experienced it.
Greatful for any advice.
