Hi
Im just making the wiring diagram for my DBW setup using M130.
I have a dual track Bosch Pedal sensor and will use AV1 and 2 for the inputs.
The Throttle bodies have a dual track sensor and the Servo unit also has a dual track sensor.
Looking in the M1 tune I see that Pedal sensor dual track is ok, the Servo dual track is ok but the TPS only has one track.
Have I interpreted correct ?
In which case which sensor should be used for the TPS position - the servo or throttle body .. it seems more logical the actual throttle body should be used in case of linkage issue ..
Thanks for any help
