Ecumaster CAN Switchboard
Postby yai111 on Mon Aug 08, 2022 4:25 am
Hi
I am currently working with C1212 dash. I want to use Ecumaster CAN Switchboard (V3.0) for addition input via CAN. Does anyone have Motec dash communication setup file (*.CC9) for this Ecumaster CAN Switchboard.
The information from Ecumaster is in attached file.
Thank you
CAN Switchboard.JPG (287.96 KiB) Viewed 5932 times
yai111
Re: Ecumaster CAN Switchboard
Postby David Ferguson on Mon Aug 08, 2022 10:04 am
That default 0x640 base address will interfere with an M1 ECU -- so you should probably change that.
Postby Stephen Dean on Mon Aug 08, 2022 10:33 am
These files have the base address changed to avoid the 640 clash with M1 and Mx00 messaging, you can change it back if you want or run the Switchboard on the second CAN Bus and share the inputs.
CAN_Switchboard_722 0x722.CC9
(14.33 KiB) Downloaded 802 times
CAN_Switchboard_721 0x721.CC9
(14.33 KiB) Downloaded 569 times
CAN_Switchboard_720 0x720.CC9
(14.33 KiB) Downloaded 675 times
Postby yai111 on Tue Aug 09, 2022 6:28 am
Thank you David Ferguson, Veracity Racing Data and Stephen Dean, MoTeC for very fast reply.
I will change the base address as per recommend to 720.
yai111
