Hi
I’m new to programming and working with electrical stuff and need some advice on how to connect a cartek xr battery isolator to my pdm30/M880.
I think I like to connect the M880 engine kill signal to an output on the pdm so I can kill the engine with the start button and use the same output when I get the kill signal from the xr unit.
And use one input on the pdm for the kill signal from xr unit (12 volt when running and grounded when killed)
(Xr unit kill engine 50ms before shutting down the complete car)
Is this a correct way of using these 3 units in an smart way?
Due to the pdm 30 only has 16 inputs I don’t knows if I will have enough in the end so I don’t like to waste them more than I need.
Emil
