Cruise control
Cruise control
Postby greenamex2 on Fri Jun 24, 2022 7:23 pm
Hi all
Interested in using Build but as you only seem to have the GPA package to start from and I need Cruise Control.
How difficult is a Cruise Control module to create?
As background I have been programming professionally in multiple languages (Machine code, Assembler, Perl, Python, C etc) for over 40 years.
greenamex2
Re: Cruise control
Postby Stephen Dean on Mon Jun 27, 2022 11:06 am
The M1 Cruise Control system has been built to OEM specifications, so there is a lot of validation and plausibility checking in the process (this is also why there is a lot of redundencies in the configuration requirements) to ensure that it is the safest that could be made, and so that end users out of our control couldn't cause issues by misconfiguring it. Doing this took a lot of time, testing and checking before it was released to the public.
It is possible to apply to have the latest versions of Projects.
Re: Cruise control
Postby greenamex2 on Mon Jun 27, 2022 5:45 pm
Thanks Stephen, might be in touch, definitely want SAFE!
greenamex2
Re: Cruise control
Postby rntechnologies on Fri Jul 01, 2022 8:49 pm
You can add the Cruise Control Module into your project, and then under the classes window you will have access to the cruise module.
Read the help that is attached to the class, as it will tell you what is required as an input.
Regards,
Ryan
Powertune Australia
rntechnologies
Re: Cruise control
Postby greenamex2 on Fri Jul 01, 2022 11:47 pm
Cheers Ryan, will have a look if/when I get the license.
Currently busy melting lots of skin welding the chassis.
greenamex2
Return to M1 Build
