BMW E36 M42 Startup - REF/SYNC
Postby mick41zxr on Sat Oct 30, 2021 6:29 pm
Setting up a BMW E36 318is (M42).
Having trouble getting the engine to Sync.
Able to test clean spark & injectors. Getting a clean RSC file.
REF/Sync
318is ref-sync7 - rev-sync.rsc2
RSC Capture
(64.45 KiB) Downloaded 1558 times
I believe I have CRIP set ok
CRIP
Does anyone have any suggestions.
Thanks,
Michael
mick41zxr
Re: BMW E36 M42 Startup - REF/SYNC
Postby mick41zxr on Sat Oct 30, 2021 6:32 pm
I believe this to be the CRIP Setup
M42 Crank Trigger.JPG (149.38 KiB) Viewed 15350 times
M84 file to see if I have made a mistake.
BMW 318is E36-2.m84-12
M84 Motec File
(72 KiB) Downloaded 1496 times
error
Any help appreciated.
Thanks,
Michael
mick41zxr
Postby GWRMOTORSPORT on Sun Oct 31, 2021 8:03 am
Hi Michael, had a quick look at your ECU file and the ref & sync mag levels are all 9.5v,
they need to be set to approx 1/3 of the peak voltage at various RPM sites,
From the ref sync capture which seems to be at about 310 rpm I would use ref 1.3v and sync 1.2v
set the whole mag tables to this, it should sync up and start and then do some more captures and work out
the mag levels. Also the trigger wheel looks like its either running out of true or is out of shape,
the constant dip in the ref voltages just before the sync signal needs possible looking at.
Hope this helps
Regards
STEVE
GWR MOTORSPORT
PM if you need more help
GWRMOTORSPORT
Postby mick41zxr on Mon Nov 01, 2021 8:27 pm
Thanks Steve,
Changed Mag Tables & startup up straight away.
Much appreciated.
Michael
mick41zxr
Postby muigandy on Fri May 13, 2022 5:57 pm
Thanks for trying to help!
muigandy
Return to M84 ECUs
