log file
log file
Postby andy on Fri Apr 29, 2022 6:42 pm
log file
andy
Re: log file
Postby David Ferguson on Sat Apr 30, 2022 12:55 am
Yes, there are various options to export a logged data file. You can send just a certain range of data, as well as just channels on the current worksheet.
Re: log file
Postby andy on Sat Apr 30, 2022 2:05 am
David Ferguson wrote:Yes, there are various options to export a logged data file. You can send just a certain range of data, as well as just channels on the current worksheet.
Thank you. I found a way
But there's still something important
I wonder if you can hide the channel
Please tell me how to hide channels that I don't want to show
andy
Re: log file
Postby David Ferguson on Sat Apr 30, 2022 2:45 am
I'm sorry, I thought the "visable data" option only exported the the channels currently shown on the worksheet. I just did a test and that's not the case.
Re: log file
Postby andy on Sat Apr 30, 2022 2:56 am
David Ferguson wrote:I'm sorry, I thought the "visable data" option only exported the the channels currently shown on the worksheet. I just did a test and that's not the case.
You don't have to be sorry.
be much of a help
I wonder if I can select and export the settings channel of the logging settings.
I wonder if I can hide device information.
andy
Re: log file
Postby David Ferguson on Sat Apr 30, 2022 3:06 am
Of course, you can change the logging from either a Dash Logger, or ECU = for future recorded data, I was thinking you wanted to share some existing data.
Re: log file
Postby andy on Sat Apr 30, 2022 3:15 am
David Ferguson wrote:Of course, you can change the logging from either a Dash Logger, or ECU = for future recorded data, I was thinking you wanted to share some existing data.
That is not my question
The channel you set in the Dash Logger
You want to delete channels in some i2 files when you send them to someone else.
Is it possible?
andy
Re: log file
Postby adrian on Sat Apr 30, 2022 9:37 am
To export only certain channels, add them to a T/D graph and then right click on the graph and click 'Export Data'. Under 'Source Channels' select 'Visible Channels' and your exported file will only have the channels in you T/D graph.
Re: log file
Postby andy on Sat Apr 30, 2022 6:43 pm
adrian wrote:To export only certain channels, add them to a T/D graph and then right click on the graph and click 'Export Data'. Under 'Source Channels' select 'Visible Channels' and your exported file will only have the channels in you T/D graph.
Thank you very much.
I have one more question
I wonder if the Details will remove the Device part
andy
Re: log file
Postby NathanB on Mon May 02, 2022 9:41 am
If the "include device config" box is unchecked, then the config will not be embedded in the log file
No device config.png (119.39 KiB) Viewed 7913 times
