SYNC ERRORS
Re: SYNC ERRORS
Postby kevdachev on Sun Apr 17, 2022 9:48 pm
Sorry Sean sent pics too big so have resent them!
kevdachev
Re: SYNC ERRORS
Postby Stephen Dean on Sun Apr 17, 2022 10:20 pm
Is that an embedded magnet trigger wheel? It looks like the sensor is also reading the ring.
A falling edge on the Ref and setting the Trigeer Voltage to 1V may work, it depends on whether that bounce increases with engine speed.
Re: SYNC ERRORS
Postby Sean on Tue Apr 19, 2022 12:15 am
Stephen, yes, that's an off the shelf MSD embedded magnet trigger wheel and pickup. Normally used with something like a MSD 7AL. The trigger wheel and the round pins are aluminium.
Kev, the picture of the ECU has answers one question, it appears to be an M800 rather that an M400. Can you post the actual configuration file from the within ecu please.
In my experience, if it was running fine before you've done a freshen up, most often the culprit isn't the ecu. I'd advise verifying the basics, cranking compression, valve lash, fuel pressure, all the basic stuff. With ecu manager open check all the sensor channels and see if the values make sense. If it's not run for a while check injectors are firing and aren't stuck. I'd always recommend a flow check on injectors at rebuild.
Sean
Re: SYNC ERRORS
Postby kevdachev on Tue Apr 19, 2022 8:01 am
Sean, Steve sorry about that youre right it is a M800. I am checking everything I can think of. I just cant understand how it can fire and run with the Sync , No Sync errors. If the cam and the crank are in sync how does it run? Im a bit confused!
Kev
kevdachev
Re: SYNC ERRORS
Postby Stephen Dean on Tue Apr 19, 2022 10:23 am
HI,
If you have the view screen open when cranking, the errors are held until reset. This means that the eroors that occur during cranking will remain in place. If you crank the engine with the view screen open, keep pressing the reset errors button to clear the errors, it is only the errors that come back that you have to be concerned with.
Re: SYNC ERRORS
Postby kevdachev on Thu Apr 21, 2022 3:03 am
OK this is all a big learning curve for me. I have altered the timing positions and some of the wiring and cleaned all the sensors. I now have no errors at all. But the engine will still not rev. The lambdas go very lean when I try to rev. It revs to maybe 2500rpm. The fuel pressure is good at tickover and when I try to rev. I dont think 8 injectors would all fail simultaneously. Fuel lines are clear pump is good. Sorry to be a pain but Im stuck with this fault.
Kev
kevdachev
Re: SYNC ERRORS
Postby super7 on Thu Apr 21, 2022 3:22 am
Are there reasonable values for the TPS sensor?
super7
Re: SYNC ERRORS
Postby kevdachev on Thu Apr 21, 2022 3:33 am
TPS sensor reads from 2.5% to 100% which I have always had.
Kev
kevdachev
Re: SYNC ERRORS
Postby Stephen Dean on Thu Apr 21, 2022 2:24 pm
Does it have enough fuel in the fuel map to run the engine at the higher engine speeds?
Re: SYNC ERRORS
Postby Sean on Thu Apr 21, 2022 6:21 pm
Have you verified that the MAP sensor is reading correctly at idle, the numbers make sense, and that it's changing readings as you change revs. Also verify it's connected to correct port on the boost side of the manifold? And check that the fuel pressure reg is connected to the boost side too, assuming you're using a rising rate reg. My instinct says it's a connection issue rather than an ECU problem as such.
Sean
PreviousNext
