After playing a bit with the knock control function, i've managed to make it work, but i have some questions:
-The knock threshold table, sets the amount of knock that is allowed from what ? What channel determines the actual knock percentage.
-The knock input is calibrated in volts, where are the volts converted to a percentage, to take into account in the knock threshold table?
-The long and short term retard don't affect the ignition timing, unless i use ign comp 1 and 2 table, and use the knock trims as axis, is this the correct way to do it ?
