by David Ferguson on Thu Mar 03, 2022 6:24 am
In your package, on the Transmission->Gear Shift Analysis page. What are the range of values on the channel "Gear Lever Force" when you activate the shifter both up and down with the clutch in (computer connected, engine can be running or not -- try both.
You need to look at those values and either change the "Gear Lever Force Threshold Up" or "Gear Lever Force Threshold Down" you'll see this on your Transmission->Gear Shift page.
Or alternately, you could change the scale of the sensor so that it reaches the current values. The Sensor input is configured on the Setup-Inputs->Chassis A page. You need to make sure the Gear Lever Force Sensor Offset is correct when there is no force on the sensor (just highlight the line and press "Q" with no load), and the direction of the force is positive on an upshift direction (ie, Gear Lever Force is positive). If you need to invert it, you can change the sign of the channel "Gear Lever Force Sensor Scale"
