Data is missing on logged data
Postby Phillippe68 on Tue Feb 01, 2022 6:56 am
Hello
When i download "logged data" on my computer, some data are missing or wrong :
the steered angle is present on the monitor channel but missing on i2 standard
and the gear is wrong neutral is 2 and 5 gear is 8 !!
Someone can help me ?
philippe
Phillippe68
Re: Data is missing on logged data
Postby David Ferguson on Tue Feb 01, 2022 9:08 am
You may need to add the channel to list of logged channels under Functions0>Logging in your dash manager.
Regarding your gear channel. What are your settings under Calculation->Gear Detection? Or does the Gear channel come from an ECU / GCU? You may need to fix it there.
Postby Stephen Dean on Tue Feb 01, 2022 9:24 am
Also check that the logged Gear channel is the correct channel and that there hasn't been a table built to interpret the data from a other source to match the MoTeC display requirements.
If it is a gear sensor wired directly into the SDL then you may need to recalibrate the sensor.
Postby Phillippe68 on Wed Feb 02, 2022 2:50 am
Hello
Is this in that list ,that i must check ?
Phillippe68
Postby Phillippe68 on Wed Feb 02, 2022 2:56 am
For the gear , the sdl is connect to a life racing ECU
Where i can find if a table has been built to interpret the data
Phillippe68
Postby Stephen Dean on Wed Feb 02, 2022 9:29 am
For the Gear Position, have a look under Calculations | Tables as this is the most logical place for this to be done. I've also looked at one of the CAN receive templates that we have for the Life Racing F88 ECU's, and for the Gear position channel in the that template we have an Adder of -2, this will drop the raw CAN data down by 2, so a channel that is transmitted from the ECU as 4 will be displayed in the Dash as 2. This change may need to be done in the CAN template that you are using as well.
Postby Phillippe68 on Thu Feb 03, 2022 4:58 am
Hello Stephen
That what i have
Philippe
Phillippe68
Postby David Ferguson on Thu Feb 03, 2022 5:19 am
OK, so if you want to use that - make sure you log the channel "SDL Aux 1 Condition" and use that as the Gear channel in your analysis.
Personally, I would use different channels, with the final result I want to display, log and analyze being "Gear".
I think Steven's suggestion of fixing the template to use adder -2 for the channel "Gear" is the right solution.
Postby Phillippe68 on Fri Feb 04, 2022 6:30 am
Hello
Yes thank you, the" SDL Aux 1 Condition" was not in the "loging set up" list
I just added it and it works
Thank you for your help :-)
Philippe
Phillippe68
Return to ADL, ADL2 and SDL
Users browsing this forum: No registered users and 25 guests
