Vector CAN DBC - Import in C185
Postby koushik_turbo on Thu Jan 27, 2022 11:45 pm
Hello There,
I am using a C185 Logger and I have a question regarding Import of a DBC File into C185 Dash Manager.
I would like to know does Motec interpret the "Factor" and "Offset" of a standard Vector DBC file ?
How is the " Multiplier ", "Divisor" and "Adder" is populated after importing a vector DBC file.
What is the mathematical relationship behind ?
Looking forward for your inputs.
Please write only if you know the proper answer and dont BS around, this will just clog up the thread.
Cheers
koushik_turbo
Re: Vector CAN DBC - Import in C185
Postby adrian on Fri Jan 28, 2022 9:17 am
In the Dash the channel value is calculated as
(Raw CAN Value x Multiplier / Divisor + Adder) x Base Resolution
The dbc import works out a whole number fraction and adder to best represent the factor/offset of the dbc file given the resolution of the channel and the channel range (number of bits).
Postby koushik_turbo on Fri Feb 04, 2022 8:18 am
Thank you Adrian.
That helped.
Cheers
koushik_turbo
Users browsing this forum: Majestic-12 [Bot] and 18 guests
