Negative Hysteresis Value?
Postby glausb23 on Fri Jan 28, 2022 5:41 am
I have a 0V threshold voltage (2-wire magnetic-type CKP sensor) which in its current configuration is a rising edge trigger. Since the hysteresis serves as a "warning" to the ECU which tells it that the trigger (threshold) voltage is approaching, would I enter in for example, -0.5V as the hysteresis setting since the CKP output voltage is technically negative as it approaches the 0V threshold on the rising wave--or is hysteresis always entered as a positive value regardless of voltage polarity?
Any clarification on this would be very much appreciated!
Benjamin
glausb23
Re: Negative Hysteresis Value?
Postby Stephen Dean on Fri Jan 28, 2022 8:54 am
You enter the Hysteresis value as a positive number and the M1 handles it correctly depending on the Edge setting for that pin, you do not need to use negative values.
Postby glausb23 on Fri Jan 28, 2022 12:10 pm
Perfect, thank you for the clarification!
Benjamin
glausb23
