Coldstart problems with honda K24
Postby bko on Tue Jan 11, 2022 12:16 am
Hi Guys,
have a problem with my honda k24 with a m800 ecu.
I often have cold starting problems. During the cranking, the rpm fluctuate between 140 and 320 and then suddenly I briefly comes to 800 rpm and fall out of the cranking table and the start does not work.
here is a short video clip
https://www.youtube.com/watch?v=URB7I8IF0ww
What have i tried so far?
INJ timing higher value
Higher dwell settings
-20 to +15 ignition while cranking
more cranking fuel
less cranking fuel
more TP% while cranking
less TP% while cranking
more first injection
less first injection.
In most cases i have the errors error sync signal and No sync error signal during startup. but i don't think it has anything to do with the failed start. If i have a great hot start, i have the error too and after reset errors it comes never back.
a friend has the same problem with his k20 and motec m800.
Does anyone have any idea why this could be?
20220110-0320203.ld
(243.79 KiB) Downloaded 711 times
bko
Re: Coldstart problems with honda K24
Postby SprinterTRD on Tue Jan 11, 2022 12:13 pm
The video shows you have a Error with the Sync sensor. I would do a REF/Sync capture with the spark plugs removed and the injectors not connected. then set the REF/ parameters.
SprinterTRD
Postby bko on Tue Jan 11, 2022 12:44 pm
Hi Sprinter,
thanks for the answer.
i have attached another logfile. In this logfile is another fail start.
At the end of the log file I have a working start as well.
You can see i am ref / sync syncronised under a second and the same errors came repeatedly.
20220110-0320202.ld
(112.5 KiB) Downloaded 767 times
the ref sync setup is for my honda correctly set
bko
Postby David Ferguson on Tue Jan 11, 2022 5:17 pm
On my working K20 setups, I have both Ref and Sync Sensor Edge Polarity set to 1 (Rising Edge)
Also, the Ref and Sync Filter tables both have 124 for 0 & 500 RPM
Postby bko on Tue Jan 11, 2022 6:18 pm
David Ferguson wrote:On my working K20 setups, I have both Ref and Sync Sensor Edge Polarity set to 1 (Rising Edge)
Ok thanks! I will try :D
You never get an sync error on your K20? :o
bko
Users browsing this forum: Auto Sport Elect, Bing [Bot] and 13 guests
