by David Ferguson on Wed Dec 22, 2021 1:51 am
This may seem odd (but you have to think oddly when looking for a workaround), but have you tried using a circular gauge, and making your line the needle. You can eliminate all the other elements, and scale it so the value represents the degrees relative to vertical.
Here is a demo project where I used an image of a line with arrows as a needle, The Math Constant channel specifies the angle when the DC is running (simulation or in a dash), but to get the pages preview to look correct, I had to change the first value of the needle range to be the same angle. (seems like a bug that the needle position doesn't honor the Preview Value).
- Attachments
angle arrow line demo.dcproj
- Demo Project showing an angled line using a circular gauge needle
- (22.84 KiB) Downloaded 966 times
