M800 wheel speed sensors
Postby Richard0990 on Fri Oct 22, 2021 11:01 pm
I am running traction control/ launch from a M800 and would like to change the wheel speed sensors from the trusty 1gt101 Honeywell units to a newer replaceable item, the Honeywell units are no longer made?
Most of the newer types require 10>30 volt supplies however the Honeywell type use 4.5v is there a way to change the supply voltage to the sensors so the new ones work, I am sure I have overlooked this somewhere.
Thank you all for you top tips,
Richard
Richard0990
Re: M800 wheel speed sensors
Postby David Ferguson on Sat Oct 23, 2021 1:08 am
Only by modifying the harness. If you are using hall sensors, you might just try them with the 8V supply, many 10-30v seem to work fine
Users browsing this forum: Bing [Bot] and 12 guests
