I have a 2011 R35 GTR with recently installed PnP M150 ECU. There is a problem with the 2nd, 3rd and 4rth secondary injectors - output test does not go through.
I have checked wiring, pinouts and ECU channels - everything looks just fine. It seems like the problem is not the only one and is associated with the OEM hardware or wiring - the vehicle has signs of aftermarket interventions into the electronics and wiring.
The thing that is slightly weird is that digit "1" appears after the ECU Serial # on the M1 Tune screen (like it does when the ECU is plugged in 12V on the bench to update/check License or Firmware). Please have a look at the screenshot.
Could you advise on the condition which is required to skip that "1" digit and what are your suggestions to look in?
Thank you.
