User Conditions Without a Standard Channel
Postby HKS_TRD on Sun Sep 26, 2021 3:23 pm
I'm trying to set up my alarm acknowledge button to also reset my trip meter when I hold the button for 0.5 seconds
I tried to copy the approach used for display next line and display mode change but I hit a brick wall because there isn't an actual channel for the trip meter reset.
Is there a way around this, I couldn't work out if there were generic user channels available which I could use for this purpose and then assign it to a trip meter reset function and then assign that to the alarm acknowledge user function
HKS_TRD
Re: User Conditions Without a Standard Channel
Postby quadcam on Sun Sep 26, 2021 6:16 pm
Yes, in the User Conditions Setup - Add - Change User Condition window select a Condition for the Output Channel and after you have configured the User Condition you can change the name in Tools - Edit Channel.
quadcam
Postby HKS_TRD on Mon Sep 27, 2021 8:15 am
Is there any condition in particular I should be selecting before I then rename it
HKS_TRD
Postby David Ferguson on Mon Sep 27, 2021 8:16 am
Good Choices are GP Off/ON xx
Postby HKS_TRD on Mon Sep 27, 2021 8:18 am
Thanks guys
So basically I am re-purposing something I am not otherwise using
HKS_TRD
Postby David Ferguson on Mon Sep 27, 2021 8:19 am
Yes, the GP channels are channels with the correct units, that you can use for whatever need you have.
BTW - for things like resetting a trip odometer, I would just put the conditions (Reset equals True for 4 seconds) in the conditions -- no need to create a user condition / channel if you don't need to log it.
Postby HKS_TRD on Mon Sep 27, 2021 8:22 am
I tried using reset = true for 0.5 seconds but because I am using the same button for the alarm acknowledge it was then activating that function of the button as well
HKS_TRD
Postby David Ferguson on Mon Sep 27, 2021 8:25 am
Yes it gets tricky overriding a few buttons. More buttons is usually better.
Postby adrian on Mon Sep 27, 2021 10:10 am
In Dash Manager go to File>New>M1. Go to the User Conditions and copy the 'Alarm Acknowledge' and 'Session Reset' conditions. They are exactly what you are trying to do, just change the time for the reset channel from 2 seconds to 0.5s.
Postby HKS_TRD on Mon Sep 27, 2021 10:23 am
Thanks I'll give that a shot
HKS_TRD
Users browsing this forum: Bing [Bot] and 2 guests
