Hi there,
M142 with GPR-DI firmware.
Using an analogue temperature input for coolant temp sensor and want to set the translation table based off resistance. It is currently set to voltage, can this be changed? Or do I need to calculate the voltage at the pin based off the 1kOhm pull up to +5V?
Cheers,
Dave
